I have a pretty big setup consisting of 8 Sunny Boys (1 is a US-40 the other 7 are US-41 models). Total AC capacity if about 55 kW.
I just changed how the grid feeds into the whole system and it now looks like this:
![diagram.jpg diagram.jpg](https://diysolarforum.com/data/attachments/118/118289-0a7554c4dc78148574d99037c6b5791d.jpg)
Before the grid fed into the House which is where my disconnect, transfer switch and generator were located. So when the grid went down, the Sunny Boys went offline for the duration of the outage and the generator would kick in to keep the house powered.
Now that things have been changed, when I loose the grid, the generator will kick on and power both the house and the shop building. This means that the Sunny Boys will see power and start generator power.
I know the Sunny Boys will slowly reduce output between 60 and 62 Hz. The house will draw a constant 3 kW give or take 24/7, but will have peaks much higher than that when the heat pump kicks on, dryer, well pump, etc.
The generator is this guy:
![kubowiringdone-01.JPG kubowiringdone-01.JPG](https://diysolarforum.com/data/attachments/118/118291-419e6e8013938a7a3c74aa04b9d0bb26.jpg)
Its a 2.0 liter 4 cylinder turbo charged unit. Naming plate on it as follows:
![IMG_0072.jpeg IMG_0072.jpeg](https://diysolarforum.com/data/attachments/118/118292-1c1959979d706134a7c4a8123fe198da.jpg)
Should I adjust the rpms to get right around 62 Hz with no load, simulate grid failure by throwing the 400A disconnect, and then see what happens when the ~ 3,000 watt constant loads at the house comes on to see if the Sunny Boys starts to contribute power to the loads?
If not, then start to slowly lower the rpms on the generator until they do?
Also, I assume I should leave the SBs in UL1741 mode? I do have a Grid Guard Code and can play with the parameters on the inverters as well.
Just curious if anyone has been down this road before and if it ended in a pile of melted metal and plastic.
