SilverbackMP
- Apr 4, 2022
- 928
All, I am hoping you can help me troubleshoot what's going on with my system.
Currently I'm on the other side of the globe don't have remote access. (I was supposed to be return within a couple of months but that hasn't happened).
System consists of
3x Sunny Boy 7.7s
4x Sunny Island 2P2S
REC Master BMS with slave BMS and batters made up 230AH CALB cells.
Since we commissioned them, they have been going offline about once a week.
Usually throwing out errors 501:
"The power frequency is not within the permissible range"
Now they won't stay on line more than a couple of minute and one is also throwing an Error Code 4301.
It kicked off long enough that it drained the batteries (they have been staying in the 90% range). I THINK that is what happened anyhow. Possibly my mom didn't check soon enough? Although she checks several times a week (she is still on their old Outback system; we aren't going switch her power until we prove this out. My shop is on the SMA power; only constant load is a newer upright freezer).
I think I have multiple issues as most of the cells are 3.3 but one is at 2.8. That 2.8 v cell (I think) caused all of the batteries to disconnect as it was set as the low limit in the master BMS. So we turned the battery with the wild cell completely off (off switch on the slave BMS and switched off the battery breaker to the bus bar). That helped the system stay on for a few minutes longer and it started getting a charge. Then several minutes later the Sunny Boys stopped working. And the whole system went down (again).
We have strings of 12 Aptos 370 watt panels going into each A and B MPPT inputs. Rated Open Circuit Voltage per panel is 40.8. Here are full specs:
We aren't using the C port of the Sunny Boys. Each string has been averaging around 460v on a sunny day.
Is it possible that we are violating maximum voltage for the Sunny Boys and this is causing the issues?
I wouldn't think so:
Rated MPP Voltage range: 270 - 480 V
MPPT operating voltage range: 100 – 550 V
Maxium voltage: 600v
All three inverters feed into a GE (I think) 225A panel. Could be the breakers causing issues with the Sunny Islands and they are going ape shit causing problems with the Sunny Boys? I know @Hedges had issues with breakers and different resistances in the past and switched to MidNite Solar 60A breakers. But this completely offgrid and I think his issue had to do with grid tie and also breakers being thrown. We haven't had that problem.
Any ideas?
I am going to send a link to my electrician so he can monitor (former industrial electrician, retired power plant administrator, now does a mixture of excavation and electrical, leaning towards industrial/commercial/agricultural).
System consists of
3x Sunny Boy 7.7s
Any ideas?
