Felicity BMS EDMS program
solarizelb
Kindly, if anyone has the EDMS program i need it, i have more tha 6 batteries in parallel tha i need to check, and felicity is refusing to give the program even though i bought from them in total more than 100 batteris
  • EDMS_V1.161.1222.7z
this is provided by them when i requested to update my battery FW version, however i am unable to communicate from my PC Win10 to it through the serial to rs485 or the usb to RS485 cables provided with the battery.
Show me the photo of converrter rs485
i am using the provided seiral rs485 cable
I'm using three different cables and can't connect to the battery. Is there any particular instruction to be able to connect to the battery? I have windows 10. Using the program in post #6
As this has now been posted to the forums and apparently they are no longer using it, here is a newer version.
If you fuck up your batteries, down to you !!!
  • EDMS_V1.71.0329.zip
that's the correct one above , this what was posted
whatsapp-image-2023-01-02-at-6-33-28-pm-jpeg.127504
What's a pinout?
