Felicity BMS EDMS program
hi guys,
just got Felicity LPBF48300
is it even possible to connect it's BMS to MUST PH18-5248pro inverter?
issue is: inverter doesn't charge battery over 53.5v
yet battery shows 4 green LEDs, inverter shows 100% SoC
Oh yes it is possible. The MUST PH18-5248 Pro Inverter has an overcharge protection at 60V. So you should be able to safely set your Max Charge and Float at 57.6V
See here:
See here:
thanks
already configured volts/amperes/etc.
I guess I put my question incorrectly:
is there way to connect via CAN/485 so inverter will be able to see real SOC in %?
tried via RJ45. PINs according to manuals. yet, looks like my MUST inverter is missing some protocols.
Found youtube video where it works with growatt.
thanks
Despite MUST is one of Voltriniks clone it doesn't support Pylontech protocol.
So looks like answer to my questions in NO
But it will work with PowMr 10.2kwt I'm about to upgrade ti. As it does support PYL protocol.
Felicity battery manual says:
Voltronic/Kodak/RCT/Mecer Axpert and InfiniSolar series communication.
1. Communication Cable Pin: 5,6(Felicity, any port)——3,5(Inverter, BMS port)
2. Setting steps on inverter: Setting→14→PYL.
3. Sign of successful communication: Can check the battery SOC on inverter
Hey everyone,
I’ve just got the Felicity LBA48170, and I’m using a Powerland 5600W inverter. Are they compatible or not? Also, where can I find the USB to RS485 in Lebanon?
I'm using three different cables and can't connect to the battery. Is there any particular instruction to be able to connect to the battery? I have windows 10. Using the program in post #6
Just incase u are still looking for this
Many things might be responsible for this. >Battery Age, >Battery Internal Resistance, >Unbalanced cells, >Inverter Parameters (Settings).
You should run the charge and discharge cycle for some days, maybe weeks and see if there will be a difference.
You can also send me your number, I'm also in Abuja. I could come check things out for you to make sure you got everything right. See my own setup below.
2x 8KW Deye Hybrid Inverters EU-Version.
4x 15KW Felicity LPBF48300 Battery Packs.
24x 600W Canadian Solar Panels.
10x 540W Felicity Solar Panels.
Pls how did u configure ur communication cable ?
Follow these pictures for your PinOut configurations for both ends
For Simplicity:
CAN communication: Felicity End: Pin 3 CAN-L, 4 CAN-H. Deye End: Pin 5 CAN-L, 4 CAN-H.
RS485 communication: Felicity End: 5 RS485A , 6 RS485B. Deye End: 2 RS485A, 1 RS485B
For Simplicity:
RS485 communication: Felicity End: 5 RS485A , 6 RS485B. Deye End: 2 RS485A, 1 RS48B
Hi, any help
At the moment I can't get a connection between Felicity battery (LPBF48300-N) and IVPA7548-US inverter to recognize and monitor the battery. I have tried DipSwitch recommended 1-0-0-0-1 and several others like 0-0-0-0-0, 1-0-0-0-0, and it does not connect (The C icon does not appear on the inverter). I have used the cables provided by Felicity as well as others that connect only PIN 5 and 6 as suggested by support and nothing has worked. I am connecting between the COM port on the battery and the RS-485 on the inverter.
I am also receiving a warning message code (51) when battery reaches 54.7 V and it disconnects the PV input without allowing the battery to reach the max voltage configured which is 57.6V.
Additionally I received the wifi module to connect via the RS232 port but the communication cant be established.
Any help on how to connect the battery to the inverter and the wifi module too? Does anyone know the pin diagram of the inverter for these ports RS232 and RS435? Attached are some picsIMG_3462.pngIMG_3312.jpegIMG_3252.jpeg
For Simplicity:
Hello,
Do you mean that we should either use CAN community OR RS485? We can't / shouldn't connect both protocols at the same time?
Thank you in advance,
Hi, any help
Any help on how to connect the battery to the inverter and the wifi module too? Does anyone know the pin diagram of the inverter for these ports RS232 and RS435? Attached are some picsView attachment 258389View attachment 258390View attachment 258391
hello, did you solve this Issu, (communication cable (5,6 to 5,6) please tell me.
- I used the blue adaptor RS485 and it always failed to connect. I changed couple of drivers and so on. Not working.
- From a friend I received the black one. Same drivers. It worked immediately.
Hello, I spend the same problem, I cannot communicate with the BMS of the battery, I have the same RS485 adapter, you can facilitate the software you occupied, you used the RS485b Pin 6, RS485a Pin5. 2 3 4 off 5 on so I have greetings
You can ask for the software to felicity solar. I can share the software with you if you want. I have receive it through whatsapp.
Thank you very much for having it, since I have spoken with the people at Felicity and in conclusion the BSM is not programmed, the battery when activating the breaker and measuring I have no voltage at the output, yes I will apply the warranty here in Chile, can you send me the software to lucky629@gmail.com.
greetings.
Hello! I just bought Felicity battery 15kWh. I also use EASun SMG 11kW. Did any of you communicate them together? Which cable should I use? Shall I configure battery or inverter somehow? I searched a lot in internet but i didn`t find aything useful. Thank you!
