MartyByrde
Off-Grid Innovator
Hello, Off-Grid I currently have two SPF 3000TL LVM-ES inverters connected to a 60 amp panel box. This currently outputs 120V.
I would like to add a SPF 12,000T DVM MPV inverter to my system.
All three inverters would be connected to the same 90kW battery bank.
Would it be better to:
1) add a second 100A panel box specifically for the SPF 12000T DVM MPV. And ground the new 100A panel box to the existing 60A box. The 60A box and solar panels are grounded to two 8’ grounding rods outside.
2) (see attached drawing) upgrade my existing panel box to a 200A. (So only one panel box). And back feed the inverters. The SPF 12000T has two lines L1 & L2 that would feed into an 80A double pole breaker. The two SPF 3000TL each have one line L1. That would “share” / both feed L1 into a 50A double pole breaker.
I want to still output 120V, with the option to output 240V.
The Neutral and Ground for all three inverters would attach to the panel box copper busbars, which is connected to the two 8’ grounding rods outside. Do I have this right?
I appreciate any help! Thank you.
