Hi All, been down this rabbit hole known as diy lifep04 for a couple months now... I`ve built a small 32ah battery for the oil pan preheater on my Subaru with a JK B2A8S20P-H bms in a Maxitrac battery box complete with heating pads and a heat distribution plate under the cells. Works great!
I`ve bult a proof of concept 24v power backup for the gf`s house in the frozen north with 2 100a 12 Chins smart batteries wired in series with a 24v Victron 1200va inverter.
Now its time to build a larger permanent battery to replace the 2 chins batteries that were purchased before I was comfortable building a battery from scratch. The biggest question at the moment is an enclosure for said battery.. In my mind I`m looking for a diy enclosure simlar to a Seplos Mason kit, something that I can bolt cells into and ideally add my own bms. Anyone have suggestions on 24v enclosures with or without BMS?
