Excellent ideas, thanks. Do you think those aluminized-looking emergency blankets would work, maybe they are mylar instead of aluminum.
Mylar, while it looks like aluminum, will not stop an EMP. Won't even slow it down.
I do not know what the blankets are made of, but I would strongly suggest sticking with what we know works. Steel, copper and aluminum. Even better is when you can alternate materials like I did. My large Faraday boxes are made of steel, then each item that is placed inside is first put into a DriShield 3400 bag. Items of critical importance, like HAM Radios, laptops, and solar charger/inverter equipment, are all behind 3 layers of Steel-Aluminum-Aluminum.. With each layer providing about 40 to 45db of attenuation, their survival is up in the 99.99999% range.
A single layer Faraday cage, properly made, will protect 90% of your stuff 90% of the time. Two layers will protect 99%, 99% of the time, and three layers is just goofy "It must survive" territory.
Most of my stuff is behind two layers.. The steel box, and then a DriShield 3400 bag.. that's probably good enough for almost everything.
The DriShield bags are nice because you don't have to seal them, just fold them over on themselves a couple times and tape them off. Very easy to open back up.
Aluminum foil works, but you basically have to destroy it to get the item back out, so I suggest only using it for stuff that will only come out in a real emergency.
