MurphyGuy
It just needs a bigger hammer
- May 20, 2020
- 4,129
An EMP attack has almost nothing in common with a CME produced from a solar flare. They have about as much in common as a high pressure fire hose and a tsunami. Yes, its still water doing the damage, but they are very different.Well a EMP attack is similar to a high class solar flare so it depends on the amount of magnetic radiation the best shield is a lead unless you want to construct a Faraday cage and can be smart but hard to do post build.
The best shield is not lead, not even remotely close. For an EMP attack, the best shielding is silver, but since that stuff is ridiculously expensive, the 2nd best is copper, and not far behind copper is aluminum. That said, none of it is really important as a simple steel enclosure that is properly sealed will do the job.
But lead? What made you come up with that? Lead is used to shield from radiological exposures like x-rays, gamma and neutrons, and even then, the only reason to lead is when physical space is a concern. When it comes to ionizing radiation, every material has what is called a "halving thickness". Having Thickness (HT) is defined as the amount of material needed to cut the radiation in half. A half inch of lead, or an inch of steel, or 2.5 inches of concrete, or even a foot of dense wood, all provide about the same level or gamma attenuation.
