2.65V per cell. It's fineThe cutoff for my Daly lithium ion 3s bms is < 9 volts.
I would like it to be 10.2 volts.
What is the cutoff for the Daly 4s lifepo4?
It's not that hard to use. The Chargery is just a low quality and poorly manufactured product. With poorly designed software.
The main website shows that it is made for ebike batteries. That is probably why the cell voltage difference cut off exists, for lipoly high c rate ebike applications. Would help to show that internal resistance of one cell is not up for pushing large induction loads. I had to do this in my drone racing days. Not a feature you will need or see in a solar specific BMS.
Instant rice society? People can set up a Batrium, Orion, SBMS, Small bms much easier than the chargery. The fact that you cannot program a resistance value for a shunt is plain silly. The fact that the menu is three settings in a single line, with a time sensitive variable, is a bad design. It should have 2 options in the menu. One for manual resistance value, and a second for automatic calibration. Then the automatic calibration should have 3 separate menus for calibrating the charging/discharging/zero current situations.
These do not need to be "plug n play" but they should have good software. The software in the chargery setup menu is an absolute joke.
The graphics look like a 5 year old was on MS paint. Compare them to the electrodacus or batrium.
Also, you can take any FET based common/separate port BMS and control a relay like the chargery does. Besides the 1.2A balance current and beeper/led notification, what is the benefit of the chargery?
I disagree. High deviation can be used to detect poor connections.Yes, a software update would fix nearly all of these issues. It seems to be a fine BMS.
I promise that this BMS would sell like hot cakes if it was more user-friendly.
Also, the default settings for lifepo4 should work for most people. Having the voltage deviation cut off on a lifepo4 system at low c rates is pretty pointless.
I think if you order the shunt from Chargery along with the unit that it comes calibrated for that shunt.
Mine DID NOT come calibrated - had to research how and calibrate myself. I do really like this BMS, personally.
What I'm interested in is to understand the permanent current drain of the chargery SSR holding coil. I suspect this might be a couple of hundred milli amps, I'd like to avoid permanent drain in a RV application. This would be my rejection criteria for this system.
Please elaborate on this statement. Show me an equally priced bms with similar features that comes in an anodized aluminum case.The Chargery is just a low quality and poorly manufactured product.
For us DIYers with remote monitoring needs beyond the range of BlueTooth, it's the only BMS in its price range with an auxiliary serial port. There's several of us on this forum that have taken advantage of this feature.Besides the 1.2A balance current and beeper/led notification, what is the benefit of the chargery?
Who did you buy it from?Mine DID NOT come calibrated - had to research how and calibrate myself. I do really like this BMS, personally.
After 2 months of searching I finally go with a chagery unit and then this review happened lol. I agree having a whole seperate unit for display just to have a have a crappy quality display is ridiculous. I'm banking on some successful solid state relays as the consumption of the offered relays was the only downside for me. With that being said I've never seen someone so disappointed in options before.
I have been really close to pulling the trigger on the Chargery but was really waiting for a review on it. Has me rethinking my plan.
Go ahead and get your issues documented here so Jason and the Chargery developers can see all our concerns.It appears Will was comparing Chargery to units similar to Orion Jr. That's a $600 BMS! You don't even get a display. Plus, you have the exact same issue choosing a relay.
Will's criticism of the Chargery BMS haven't really been an issue with me. I do have some issues with the two units I possess, but not those mentioned.
I seriously do not see a problem if you are just outputting a signal. I've had mine going durect to midnite classic and samlex for 6 months without any problemsI was hoping for some clarification on the usage of the relay outputs in general the back of the manual states do not let the BMS do all the work as far as connecting and disconnecting is that due to the stress that the relays cause would I still have the same issue if I use the relay output to control inverter directly as my main source of disconnecting curious as to what the actual issue is with using it to connect and disconnect
Checking this follow-up video I feel it comes down to simplicity and user friendly. I still believe the first video review was point on. I'm still interested to see if any changes are made and more updates follow.
@Will Prowse is doing what he has always done..... giving us his honest opinion based on his experience with the product and knowledge of the field. He does not shy away from saying he does not like something.... and that is why I value his videos. I know I am getting what he believes.... not what he needs to say to appease some vendor or his followers.
The other thing that I like about Will is that he is willing to change his mind as he learns more. The relays are a great example... Over time he has become less of a fan of using relays..... and he admits it. He is taking us along on his journey.
I don't always agree with what Will says, but I always value his point of view because I know it is an honest, experience based point of view. The interesting thing is that were I am not aligned with Will's thinking, it often changes to alignment over time. Either Will drifts more to my way of thinking or I drift more to his way of thinking.
