Yes, of course, that's why you have a BMS after all ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So then that require some manual actions, but the vast majority of the time you shouldn't have to do anything manually.
If you (fhorst) can't live with that then just use a separate port BMS, nobody is forcing you to use a common port BMS. But don't say common port BMS are useless just because you don't want to use them in your particular case, a lot of people are perfectly fine with using them.
