@Capt Bill
As you must have seen, mine was just the first to fail.
It was supposed to be able to to 150A (just remembered the specifications not exactly, I know it should have been more then enough)
The timing apparently was coincidence. I know 27 x 330w panels is more then most Chinese factories / R&D teams have available for testing.
And most "testing" is theoretical.
From this knowledge and the timing, after noon, my best shot was the high current that gave damage.
Now we know it's just bad buil /designed BMS.
@Denis : it's good to know that ours is not the only defective units...
The counter is at 4 (!!) With same error.
My MPPT indeed should stop before the total pack reach too high or too low voltage.
As it is new battery, it is not yet top or bottom balanced.
The individual voltages are little different.
I'm sure you are aware that @80% charge should change from constant current to constant voltage.
0.1 volt is a lot of difference in this charge state.
You also might have seen I made one cell pillow with normal lab power supply, that gave CC too long.
Voltage was way below the 3.65..
But the current was too long "high"
(3.5A)
12 watts power for +/- 5 hours was all it took.
This is why BMS is So important!!!
And why active balancer can be really important also.
I have 16* 200Ah dead lead acid battery. 4500 USD go POEF.
Different product, EASUN MPPT inveter Charged the 48v array @ 78 Volt.
I know that wrong charging ALWAYS give damage.
Failing BMS will ALWAYS give damage.
If you are lucky the kind that doesn't show directly.
It just shortened your total life cycle with 10% or so.
That is 6 months or more...
Best case scenario.
Worse case... Like my lead acid.
That took 10 days before the problem was noticed... By then it was too late.
Down hill ever since. The 800A @48v still can hold some charge, for a few hours.
That is how we lived, without BMS.
Every day around 22-23 hour...
Lights off, no more power.
All day charge the lead acids for a few hours of power. (For 5 weeks)
I did not want to risk my 2500usd lifepo4
We now have Daly BMS that works perfect. (And active balancer for monitoring Bluetooth)
Any wrong charge will give damage.
Every product in the total setup that fails probably give small spike at the moment of failure, that also will damage the cells.
How much?
Only really to determine with 2 identical setups, one that have, and the other that doesn't have the error.
