Deyedreamer
Hi all, I noticed on the DEYE 5KW Hybrid Inverter, the Float Voltage is set without the charge Voltage being available (Use Battery V Mode).
I assume the Charge Voltage and Float Voltage are the same with less current output on the Float mode.
Can someone with DEYE knowledge please advise if this is correct.
I dont see any other way of setting the Charge Voltage in (Use Battery V) mode.
Thanks for your advice.
