OrigamiTiger
- Jun 10, 2021
- 14
Hi Guys,
My mate is about to embark on a 20KW (50 pieces of 410W/405W) ground mounted solar pv install connected to a 40KW battery system.
We have compiled the following list of components to go with it. What other parts or bits would you add or improve on this install?
The solar panel mix are 40 * Canadian solar 410W and 10 * 405W.
The panels would be run in 4 strings to 2 inverters each with 2 x MPPT inputs. The inverters would be paralleled to each other.
- 12KW Hybrid Inverter x 2 (Deye/Solis/Solax)
- Ferrules
- PV Cable 2 core (positive/negative)
- AC surge protector
- DC surge protector
- 50/75mm electrical cable AC side
- AC battery disconnector
- DC Isolator
- AC isolator
- Generation meter
- Modular batteries Pylontech or Fogstar 5.12KWh battery X 8
- Battery Rack
- Consumer unit
