I was searching around on the forum and saw that same recommendation. I was looking for blue sea class t fuse for the battery, but I could not find any 150A, only 200A+ or 63A ....Watch out for those breakers unless they are made by a good well known company like little fuse, buss, or blue sea you will not get a reliable breaker
Your 50Ah battery is limited to a 50A discharge current, this will have a significant effect of fuse/breaker selection and operation of the inverter., the inverter that I'm planning on buying says that it draws 127Amps on average,
Noooo …..nooooo …if your going with a breaker / like that get the Buss 187 series .. …it’s the really good one …they cost about 60 to 70 dollars if you look good…some places will try to nuke ya for 100 or more dollars… The Buss 285/series( IIRC) is good but a lighter duty MRCB… either are light years ahead of that device…the 285 is a little less money Than the 187.My soon to be inverter manual is recommending I use a breaker between the battery and inverter for 150amps.
This is what shows up on searches, is this the right type it should I be looking for something else?
That's what I had thought since the manual where it stated 137A continuous draw also stated on a 200A battery, which I do not currently have. Eventually I'll have 4x 50A batteries but not now. Will a 125A work because the battery is much lower than the 200A example?Your 50Ah battery is limited to a 50A discharge current, this will have a significant effect of fuse/breaker selection and operation of the inverter.
Mike
Thanks for that! That's what I had thought and understood but with my growing awareness of how much I don't know I thought to ask in case I was wrong. Thanks again.Double poles are internally symmetrical. If there is an optimal current direction, damned if I know. They have a huge arc chute. Regardless of polarity, for a 55 volt system it’s overkill. I was nosy, so I opened it up to have a peek. The only short fall in the design is the holes for the terminal screws. They are threaded in copper so be careful with not going crazy with tightening. Didn’t find any torque specs so just keep it in mind when you tighten those socket heads. View attachment 158529View attachment 158530View attachment 158531
?.I didn't see any project boxes to put this in on Amazon
Neither.Does the circuit breaker protect the battery, inverter or both?
I'll rephrase. I didn't see any that it would fit inside natively. But if you're saying you found boxes that this breaker would fit in I'll definitely check again.?.
Look harder.
I went to amazon.com, searched for 'electrical project box' and got about a thousand results..
