Texas-Mark
Solar Addict
- Aug 4, 2021
- 1,314
A much better plan would be to...
Make it easier to get DIY solar approved.
Is it really that hard to do in Texas? What's the catch?Make it easier to get DIY solar approved.
A 1kW battery would run a household air conditioner for about 15 minutes. Actually, its worse than that.. A 1kW battery of the type you are talking about, doesn't even have the capacity to deliver that much energy that quickly.
The cost to implement your plan would be outrageous.
Just the cost of your permits alone approaches the cost of my suggestion.Here in Michigan, it was pretty easy.. at least in the small town I'm located near. My only complaint is that the permit(s) cost me $400 and the inspectors came three times and spent a grand total sum of about 6 minutes here.
There is no need to run an entire air conditioner off a small shaving device, and a 1kwh lifepo4 battery can supply nearly 1c discharge rate during these grid emergency situations for an hour. 1000 watts shaved off the household load for an hour is a huge amount of energy for a device not much larger than one or two car batteries that is easily portable and installed quickly. The idea is to have large numbers of these things work in concert, controlled by the utility to shave off some peak load in trouble areas as necessary. Households with out any activity to shave (all easily monitored by the utility) or with a reduced load, could be actively injecting back into the grid instead of merely shaving their load.
I didn't specify how to implement the cost of my plan, nor the cost of the device. Honestly, it should be able to be done in volume for under $500 with slight modifications to existing products. One example of how to fund it is that you could have people capable of buying one on their own get credits back from the electric company for having one connected and controllable by the utility, that costs little upfront.
These things just require cooperation from the utilities, so there is a market to sell them in volume for cost reduction. The utilities don't give a rats as* about power outages though, or relatively low cost solutions, you know the energy executives houses are fully backed up.
I doubt if it's like this everywhere in Texas, but our local coop POCO claims to support adding solar except when you try to engage them it's a whole different story. Their "solar guy" wouldn't return my calls at all over the course of four to six months. They have an open ended connection fee that they plainly state in their agreement can be adjusted at any time at their discretion and without notice. I finally spoke with a local commercial electrician and he advised me to go off grid. As he put it, they will put every possible roadblock in front of you imaginable. I find I'm much happier off grid anyway so it all worked out for me.Is it really that hard to do in Texas? What's the catch?
There I was, all proud of my work, attention to detail, accuracy, and professional work.. and those guys didn't even open a single box to look inside..
But the process wasn't difficult.. no one gave me any problems per se.
So what's up with Texas?
I would entirely agree that any energy a home pumps into the grid would be beneficial to the grid.
The extra stuff needed to make a portable power station "grid tie ready" would most likely raise the cost of these units significantly. Unlike off-grid inverters, grid tied stuff has to sense and shut down when the grid is down.. they also have to be capable of dealing with the various voltage spikes the grid produces.
They pretty much already exist. They are planning to do the same thing with EVs already.. the problem with using EVs to do it, is that they are expensive, not everybody can easily plug them in every day, they are needed for work the next day, etc.. EVs are also higher output than I am advocating for, would require an expensive dedicated outlet to be put in exclusively for charging/discharging them (not all garages have 220vac outlets in them) where as most houses have a dedicated dryer outlet somewhere near a dryer.Seems like a good idea but I suspect not practical. Imagine them using this concept with EV's and being allowed to suck 5 kW of energy from your EV whenever it was fully charged.. or some other program that allowed both EV owners and the grid operators to benefit.
Another thought, why not just take a 400 watt solar panel, glue a microinverter to it, and then plug it into the wall outlet or a 240 dryer plug? Not only would it be far cheaper to do, but it would provide a lot more than a single kilowatt hour of energy to the grid during the day.
And I think its fair to say that when your grid is stressed, its because the sun is shining making everything hot and its the air conditioners sucking up most of energy.
the problem with solar panels is that they stop supplying power at a point where everybody has gotten back home and their houses are already hot as heck from the days sun. We are talking about the grid running out of power at 7-9pm at night.. house is still hot, sun is down.
So the Texas republicans are trying to control your power? Or is there some other facet to this?I doubt if it's like this everywhere in Texas, but our local coop POCO claims to support adding solar except when you try to engage them it's a whole different story. Their "solar guy" wouldn't return my calls at all over the course of four to six months. They have an open ended connection fee that they plainly state in their agreement can be adjusted at any time at their discretion and without notice. I finally spoke with a local commercial electrician and he advised me to go off grid. As he put it, they will put every possible roadblock in front of you imaginable. I find I'm much happier off grid anyway so it all worked out for me.
Automatic setback thermostats have existed for decades.
Rooftop PV customers are forced onto time of use rate schedules, but consumers are not.
Having the A/C pre-cool the houses would make a big difference.
Having a pager to shut off the A/C would avert grid collapse.
(Totally voluntary, of course. Those who decline would simply get a pager controlled disconnect installed under their utility meter.)
No, this is all about profit margins and control by a regional coop. The state hasn't shown any interest in controlling our power. Unlike some blue states.So the Texas republicans are trying to control your power? Or is there some other facet to this?
The state hasn't shown any interest in controlling our power. Yet.
I can only speak for my own state of Michigan, which is currently rather blue(ish). There are no problems here with power or control that I would complain about.No, this is all about profit margins and control by a regional coop. The state hasn't shown any interest in controlling our power. Unlike some blue states.
It varies a lot depending on where you are.What does a meter cost you?
It is a very reliable source of power, and backed by an experienced crew.
Inexpensive compared to generator, unless it has high fixed cost.
Grid Energy Costs:
Daily $2.06/day
Peak $0.61/kWh
Shoulder $0.46/kWh
Off-Peak $0.33/kWh
Feed-in credit $0.12/kWh (excess to consumption)
Grid-tied PV
Cost per kWh of PV: ~$0.06/kWh (15 years)
Off-grid PV/battery
Cost per kWh of PV: ~$0.03/kWh (15 years)
Cost per kWh of battery: ~$0.13/kWh (3000 cycles)
