Hi I am new to the forum . Thank you in advance, I need some advice. I have a home on grid system with a big 20 panel system on the roof I have two 5 K inverters that feed power to the grid. The inverters are "Sunny Boy" from Sun Power. I would like to build a power storage system to use in case of power failure. I know I could purchase a commercially available system from sun power that would interface with their inverters however the cost of the system is a bit prohibitive. So I have set out to build a small system that could run two refrigerators my heating system and perhaps some LED lights around the house. I've already configured the power bypass to hook up a generator. However instead of the generator I would like to have a solar powered battery back up. I have purchased a 4000 W pure sine wave inverter and at this point I am running it with 2-12 V 100 amp hour AGM batteries in parallel. My two refrigerators pull about 6 A apiece. I am going to add two more batteries to the system giving me 4800 watt hrs. The other day I ran one refrigerator and some lights for about six hours on my two batteries, everything seemed to work OK but I believe I ran my battery down pretty far. I went back to grid power before anything stoped working. It took a 25 amp charger four or five hours to recharge the batteries. I am using a battery charger instead of a charge controller. One question I have is the panels are wired to deliver almost 450 V unloaded and they run at 335 V when connected to the inverters so I don't believe I could find a charge controller to work directly off the panels am I right or am I missing something? In a grid down situation I can pull 1500watts directly from my "sun power" inverters which I will use to power the battery charger. So my question, is this configuration OK? using a charger instead of a charge controller? What should the charger amperage be rated at? it seems 25 amps is far to small to charge 2 100amp hr batteries effectively let alone 4 which I plan to ad shortly. Me second question is are 4 AGM batteries enough? If I have a prolonged Grid Down situation how do I charge the next day after drawing a 1200 watt load all night, wile continuing to draw that load, And in the winter when the panels are not nearly as efficient how will that affect my charging capabilities?
Thanks so much
Len
Thanks so much
Len
