12V 280Ah LiFePo4 battery Build and Test
Haugen
Tron God
Florida
I have a background as a Test Engineer and I am building my first battery from cells.
I have some pretty good equipment and I wanted to share with the group what kind of information I manage to acquire as I apply my trade to this new endeavor
With an eye towards the science of this emerging area of power storage, I hope to aid others in making some of the more difficult decisions associated with setting up LiFePo4 batteries.
I look forward to discussions with you to make the most of this topic
Wow 280Ah - is this even a thing? I was impressed with 150Ah, so for $1600ish I could get close to 7kW battery bank? That's crazy. Hope it works out.
Most popular cells on the site right now are the 280Ah EVE cells sold by Dongguan Lightning and Xuba.
See here and here (xuba) and here (dongguan lightning)
But, if you want to see some really crazy big cells check out Winston's high capacity cells, most notably this big boy, 10,000Ah, weighing in at 335 kg / 738 lb:
I ordered the cells from Shenzen UNIS. The pandemic made the delivery time 52 days.
They arrived in good condition. The only physical damage was one label on top of a cell was peeled up on one end. It might have happened when sliding the cell into the box and the edge caught the foam.
They want me to test first before sending a replacement label.
Cell voltages as received:
1 - 3.2970
2 - 3.2992
3 - 3.2997
4 - 3.2995
I wonder what the hell 10,000Ah cells are used for, that's 40,000 Ah for a 12V pack (sometimes 3000 lbs. Half a million Watt-hours, or half a megawatt-hour! Correction: I'm a dummy, you are correct. 10,000A, 120,000Wh, 3000lb
They use them in submarines.
Reactions: Dzl
Who knows, as we move to this more distributed power network where small solar is powering more than the needs of the owner, there is probably a business plan for storing energy for keeping the grid supplied in the event of outages. Maybe an HOA putting their neighborhood on a giant UPS.
Reactions: Dzl
Power Supply arrived today!
I took some time to check it out a little and it seems to be fairly good for the cheap price.(<$100). It will put 10A into a cell. That will be important. Unfortunately we won't get to hit substantial C rates unless I get creative.
I set up cell #1 to charge it to 3.62V, but the supply loads down to 3.43V. We will have to wait and see if it will recover as the current settles out. The voltage reading on the front is off by 100mV. You can see my Fluke shows 3.43 at the terminals and the supply is at 3.51. There is about 10 milliohms of resistance in the leads causing the other 100mV of difference that is being read at the battery. I'll build bigger cables for the real testing. I just happened to have some 14 AWG wire and crimps handy to try a first check of the supply's capabilities.
Reactions: Dzl
It took a few days with only 10A charge capacity to get the cells to full charge for a top balance.
I'm now in a holding pattern waiting for the BMS to arrive.
In the meantime, I have ordered some copper and aluminum bar stock to make some improved bus bars. I bought both because I'm still debating in my head and researching which is the lesser of the two evils. Lower conductivity of the aluminum, or the galvanic reaction between copper and aluminum.
The interesting thing is that the bolts that came with the cells are brass to throw in another galvanic element. I'm leaning towards heavier aluminum bus bars as long as I can find 6mm aluminum screws to hold it all together.
Just to chip in, generally aluminium/stainless is a really bad combo for galvanic corrosion, as it seems also with brass or copper. How that equates to humidity around battery terminals I have no idea, I'd be tempted to use silicone grease on contact areas, but when I take the plunge with the Eve cells I'm going to be looking here to see what you decide. ?
Whatever I use, I will definitely put connector lubricant on it to reduce the available oxygen to cause corrosion.
I read the contents of Noalox and I'm not a fan because it has zinc suspended in it.
I have a can of SuperCorrA that does an amazing job of protecting connectors.
Set up for Top Balance. Still the little wimpy bus bars, but they are fine for 10A.
One pic showing the voltage, the other showing the current. 5.3mV across the 50mOhm shunt shows that the power supply reading of 10.6A is pretty accurate.
Copper bus bar material came in today!
If I go with this, there will be no questions about capacity should I decide to add another 4 cells.
I'll probably need longer bolts!
Still waiting for my BMS and my test load. I ordered them 4/30 and 5/2 respectively. AliExpress says they left China on 5/21 and 6/4 by air. That's the slowest airplane I've ever known!
My 40lb batteries got here faster by sea.
Tomorrow is the latest extended date that they gave me. I have 3 orders that I am going to file disputes on.
View attachment 16040View attachment 16038
I used 1" x .185" copper bar stock for my bus bars, and 20 mm stainless studs. 20 mm seemed to be the sweet spot for me for the thickness of the bus bar and the BMS leads. I put some no-ox grease on the terminals before I bolted everything down. Then put heat tape over the terminals and connections. So far so good.
McMaster Carr has aluminum threaded rod on their website. They may have aluminum screws, too.
Have you considered Dacromet coated steel fasteners?
https://www.mcmaster.com/stud-bolts/aluminum-threaded-rods/
