Okay, it's only 19% off on Amazon, but I don't remember seeing it this cheap, so save a few bucks if you want:
Good excuse to build a second battery bank. Bonus redundancy prep pointsI should get a second, just cause.
Yes. With the official VE.Direct to USB cable you just have to plug it into your Solar Assistant Pi. You might have to select Victron from the dropdown or reboot, I don't recall, but that is the cable and it's a very seamless process.Not familiar with victron, do I need this cable to connect the smart hunt to the Solar Assistant PI ?
Can you use one of these with 6 Lifepower 100h batteries?. Just starting to learn about these things and all the different makes.
Yes. The shunt sits between the battery negative and the rest of the system. You can also monitor the midpoint battery voltage to get a better idea of how the SoC is across all your batteries.Can you use one of these with 6 Lifepower 100h batteries?. Just starting to learn about these things and all the different makes.
So between the negative buss and the 4/0 cable to the system, correct?Yes. The shunt sits between the battery negative and the rest of the system. You can also monitor the midpoint battery voltage to get a better idea of how the SoC is across all your batteries.
Victron has the SmartShunt manual on their site with diagrams that demonstrate proper wiring configurations for the midpoint monitoring. It uses a separate probe with a ring terminal for midpoint monitoring.So between the negative buss and the 4/0 cable to the system, correct?
To monitor the mdpoint, suppose it needs to be mounted mid point on the buss, or no?
Price reduction also in the UKI don't remember seeing it this cheap
I think it may actually be the LiTime/Redodo/powerqueen line of products causing pricing/demand pressure. Because now they have an entire line of products including mppts, circuit breakers, ANL fuse holders etc. So if someone buys one of those batteries, they may well go for matching accessories from the same brand.My guess is that these Victron price reductions are to compete with the aggressive advertising and low pricing of Renogy products.
