“Will it balance”
Now that these cheap 100ah batteries seem to be including low temp cut off.
How about how to they do at keeping cells all balanced. Renology has a crap pile on their hands with their 170ah units going south and not being able to charge higher than 12.7v due to improper balancing.
So take your off the shelf battery of the day, charge to 100% crack the case open the case, use a bleed off resistor or car headlight and bleed off Xxxwhr from one cell then see how the BMS handles it.
Will it only balance during charging once a cell hits xxx? Or will it balance if a cell is above xxx volts?
