Juice has arrived
Whats-n-Watts
Southeastern Georgia USA
Got some batteries from alliexpress. So far so so good. Best price I could find.
the 300ah 24v looks like it had 2x68ah (8s2p) pouch cells from 2019 that only tested @100 ah total. no compression thin wires cheap bms.
also found these german videos of the 200ah 12v
which had 2x60ah pouch cells
saw a comment on one video that I couldn't relocate that said one caught fire and burned out a basement.
10kWh of LFP should tip the scales at ~185 lbs. To my eye that plywood should bowing in between the saw horses a bit more than it is.
It's not even plywood. It's 1/4" siding.
He probably has 2x4 or larger under it for support.
That said, the videos show it is one of those "if it's too good to be true" deals.
The German guy got his money back from the sales platform, not from the seller.
It's siding made out of plywood since we're trying to get technical.
Regardless of what it is my point was that if those batteries weigh much less than 90 lbs each there's not going to be 5 kWH in them.
T -111 5/8" siding. They don't even make it in 1/4"
3/8 is as thin as it gets. 3/8, 1/2, 5/8 only.
I'm just itching to know what's inside 😂😂 Will you have a shunt on the system so you can do a capacity test?
It's only a buffer really. The system is used in daylight only and has 1,200 watts of panel for a 500 watt continuous load (LED lights) during the day and intermittent use of a 15 amp table saw. Capacity isn't an issue. 👍
hope you don't use them inside, found that youtube comment:
"One of these OLPZ batteries (12v-200Ah) set my basement on fire. Several tens of thousands of euros in damage, huge effort with fire sanitizers, craftsmen's businesses and trouble with insurance companies just because you fell for this cheap junk. That won't happen to me again. Stay away from this fraudulent and life-threatening crap!"
Remember if they lied about whats inside they don't give a f@ck about safety. fake=dangerous
What does that have to with the weight? No one cares about the finer details of the plywood.
Because thicker holds more weight. That has lots to do with it. 5/8 would hold the weight just fine even if they were 86 pound each. Just pointing that out. So your comment that the would should be bowed isn't the case. You can't go by that. You my know solar but I know wood. Your method of sizing the batteries by that isn't accurate. Future reference for ya. 👍
Yeah when I ordered them I was sceptical. Some people pay student loads back. I've always paid for my education here and there. Thanks for the heads up. I filed a dispute with the store through AliExpress so we will see how it goes and I already considered fire prior to ordering. I'm doing them in a mobile set up so at the most they will burn themselves up and a charge controller only. Might strap a fire extinguisher to the box lol 😂
