My preference is aluminum unistrut over plated steel near the ocean because the plated steel rusts. I know the aluminum oxidizes but it doesn't stain the walls like rusting steel does. Stainless would be ideal but expensive and hard to cut.If you leave close to the sea, aluminium should be avoided
Is the pergola made of wood or a metal kit structure? Maybe a picture? If it's wood then it could be very simple...Its more of solar covered sun blocker. I guess a pergola?
