Dorosa
I'm new here, and pretty new to solar. If there's a better place for this thread, let me know.
I'm living in rural Madagascar with my wife and kids. We live 15 hours away from the supermarkets/grocery stores, so when we go to "town" every couple months, we load up the pickup with stuff we can't get locally, and then freeze it (sliced bread, cookies, sauces, frozen stuff, etc) and we also buy local meat and chicken locally when it's available at the quality we prefer, and freeze that too.
We have grid power most of the time, but we experience daily voltage drops (instead of 220v, it drops to ~150/160v for an hour or so), and frequent blackouts (sometimes it's every night from 8pm-8am for a month at a time).
I have a 12v 75w fridge that we have been using to keep things preserved when there are power outages. But the system I have hooked up is obviously not sufficient, or not efficient, because the fridge routinely doesn't make it through the night.
I also want to buy a 12v deep freezer, which I can get "in town".
Locally, all I can get are probably the cheapest solar panels available, and only cheap PWM 30A controllers, and only lead acid batteries. Everything is Chinese.
I currently have 3x 120w panels hooked up in parallel to a 30A controller, which is then hooked up to 2x 150aH batteries. I also have a 200aH sealed non-lithium battery, which I assume would be gel? I hooked this up with very little research. I just bought what I could find before the last cyclone came through (which shuts down the grid for a month or so) and hooked it up to have something, at least during the day, to charge stuff, and run the fridge.
After some more research, it appears my array is woefully underpowered for the battery bank, so I'm probably never charging it all the way and it's being drained to empty every night.
So my latest plan is to bump up my solar array. Locally I can source more panels and more 30A PWM controllers.
This is what I'm considering putting together.
What do you guys think? (blue is what I already have, red is what I would need to buy)
I also have a 0.75kw deep well pump to fill our water tank and a 1kw pressure pump to pump water from the tank into the house. I would love to be able to hook them up to the solar system if possible. Otherwise, I'll just be getting a small 3000w gas generator for the times the power is out but we want to take showers, etc.
