Hoping to get some direction here.
I have a grid tied system I do not touch, and an off grid system conected to a switched neutral critical loads panel due to the ng bond created when running my MPP Solar LVX6048 off batteries.
I am currently changing batteries from the main, and a battery changer. It still takes a couple days to charge the batteries (6 x EG4-LL v1) and I want to reduce this time frame.
It's time to add some solar. I am experimenting/learning and don't want to void the warranty on my professionally installed system so I am keeping the separate.
This pic show the basic setup minus the AC input into the inverter from the main.
What do I need to add say 4 solar panels to this set up. I don't need info on the panels as the LVX6048 will take 450V and max 27A.
I want to know about grounding say 4 panels (in series). Will adding another breaker to the disconnect that the changer is connected to suffice for a disconnect.
Do I need to fuse this small amount of panels.
All this is being done while I decide which hybrid inverter will replace my grid tied SMA Sunny Boy 7.7
Thanks in advance
Thanks in advance
