I think you mean 16-32 cells that would be made into 4 - 8 12v batteries.I was hoping that there was a single bms that could handle the 16-32 batteries.
Do they make a bms that will link the bms's together for complete system monitoring?I think you mean 16-32 cells that would be made into 4 - 8 12v batteries.
A BMS works with one and only one battery.
So you really need to provide a little context as to what you are trying to do if you want quality "complete system" advice.Do they make a bms that will link the bms's together for complete system monitoring?
So I could monitor each 12v 100ah 4-cell battery as a single cell and monitor 4 of these on one BMS?I think what you are missing is if you build a pack that is 12v you are making it out of 4 cells in series. But each of these 4 cells can actually be infinitely paralleled cells put together, this in effect makes one cell so if you have 4P4S with 16 cells for BMS purposes you have only 4 cells to manange because the first 4 paralleled are in effect one cell. You could even parallel 8 100Ah cells and they to the BMS are 1 cell. Like steve said what is important to the BMS is how much energy you draw out. You could have a 1000Ah battery but most likely you are going to pull a max of no more than 200Amps so you need only a 200 amp BMS.
no you would monitor each 3.4 Volt 200Ah cell (comprised of 2 100Ah cells) as one through each of the BMS leads. if yu want to monitor each 100Ah cell individually you will need multile BMS that probably will not talk to each other.So I could monitor each 12v 100ah 4-cell battery as a single cell and monitor 4 of these on one BMS?
200 amps would be more than enough power for max output on this system.
No, still only one battery per BMS.4-cell battery as a single cell and monitor 4 of these on one BMS?
This system is on an off grid cabin. When it is UN-occupied it draws 1 amp of 12v power from the batteries.So you really need to provide a little context as to what you are trying to do if you want quality "complete system" advice.
Yes that is what I need. So I need to find a 4P4S BMS for each 16 cells.No, still only one battery per BMS.
The closest you could do would be to parallel 4 cells together as a single "cell". Hook up 4 of these "4p cells" in series to make a battery out of 16 cells (4P4S).
Here is a shot of a 2P4S battery (2 cells paralleled, 4 of these pairs in series).
Note that the 4S BMS has one lead to each of the 4 pairs.
Are you totally set on 16 cells? Or between 400-800AH at 12v?Yes that is what I need. So I need to find a 4P4S BMS for each 16 cells.
Here is the Godzilla thread:Recommendations on 280 ah cells?
