Just put 16s into service with 100 ah Overkill Bms.
Did a 6 minute test with constant draw no PV input. Watched the onboard bms shunt system display (x ah of 280 ah) then shut off load and started PV input. The drawdown matched the fill-up.
So it seems accurate at that tiny test window.
Anyone here with actual experience with the Overkill over a larger drawdown and over several months monitoring it compared to an external shunt?
