AdamMillsap
- May 27, 2022
- 3
System Specs
~1600w array
Growatt SPF 300TL LVM-24P all in one for: MPPT charge controller; inverter; utility power management
Victron Smart shunt for redundant SOC monitoring
16 - 200 ah LifePo4 cells in 8s 2p configuration for 9600 Wh rated capacity - Top balanced before initial install
2 - 8s 100A 24v @OverkillSolar BMS modules
This system provides power in our Skoolie conversion. The system was first commissioned in May of 2021, and performed well, and reliably through three periods of heavy use, 5 months in the Summer of 2021, and 4 months in the Summer of 2022, and 3 months in the Summer of 2023. In the off-season, the system was left on, maintaining onboard 12v loads and kept a full-size fridge running.
The only issues I encountered during this period were:
I parked the bus 6 weeks ago and left the system running. When I checked the system two days ago, I found all 16 cells well below 1 volt! As you would expect, all the cells have significant swelling (this is new).
Questions:
1. Even if the Growatt shut off, and was not charging for some reason or another, shouldn't the BMS have gone into protection mode when the battery low voltage cutoff, and/or at the cell low voltage cutoff setting was reached? Isn't this precisely what the BMS is intended to prevent?
2. Is there any hope for saving these cells? That's a whole lot of money down the drain if not.
This was the first solar system I built, and reading through this forum, and watching @Will Prowse's YouTube channel was incredibly helpful and empowering. Thank you all for the education you provide through your contributions here! Since building this system I've built batteries for two golf carts we use on our farm, installed a direct drive solar irrigation system, and installed a 20kWh off-grid EG4 system to run our greenhouse. There are lots more projects planned for the future!
~1600w array
- Occasionally the voltage would spike toward the end of a charge cycle, and kick the inverter, and charger off. Power cycling would return the system to operational status, and eventually, I reduced this occurrence by reducing my maximum charging current.
- In the spring of 2023, after the "standby" period throughout winter, I discovered that one bank was well below the cutoff voltage (I can't remember exact voltage now). The other bank was operating normally. I slowly recharged the ailing bank, and it performed normally throughout the Summer of 2023. I did not understand how this condition could have developed with the BMS in place, but I got busy and failed to delve deeper.
Questions:
