Hey folks,
I'm currently running 2x 6500ex where each one has its own L1, L2, N, and G 6 AWG wire (using only 1 Load leg per, original design was going to use a split phase setup). I'm upgrading to an 18k that I already have but I'm not sure what the best way to turn my 2x 6 AWG connections into a 1x 2 AWG connection for Grid In and Load Out would be. I will be running this offgrid mode with grid as backup bypass.
Looking for safety, clean install and preference for using ferrules over a crimped terminal. While searching through forum I found someone recommend these: https://a.co/d/6NI77pF
Are these safe and adequate for my use case? Are there better options to consider?
