chrisski
Solar Boondocker
- Aug 14, 2020
- 5,198
I am testing running my 15K BTU on solar in my RV off a SAMLEX 3000 watt PST 24 volt model inverter and two 8S 280 ah Cells (560 ah total). Here are some stats:
Watts From Battery: 1650
Watts From Inverter: 1470
I did this with the Micro Air Easy Start Micro Air 364:
I did the 5 start Learning Runs off a 3000 watt inverter Generator.
The first learning start was 30.9 amps, and the other 4 learning starts were between 16.2 and 16.5 amps.
When I switched to my Inverter, the Start went to 18 amps.
Whenever I ran the Air Conditioner, the 120 VAC amps were between 11.9 and 12.3 amps.
Not warm enough here to turn it on and keep it on, but I should see that over the next couple of days.
Here's some start up Data:
