Just a paint job. I have to take it apart once more to cut the ends of the HSS flush with the end of the box, shorten the threaded rods by ~ what is sticking out and going to bore out the large dia holes on the side with out the springs so that if I need to change the side the springs are on I can just switch them with out taking it apart again. Ill paint it then.Looks like a great box. Are you planning to seal the plywood with anything?
Thank you for the suggestions but saving space comes at the cost of consistent pressure. If I needed to save any space, Id use shorter springs.Nice build. About your coil spring, replace it with polyurethane bushing or wave washer or disc spring will save you a good amount of space.
Still, if I have to do similar battery, I would not bother with the springs compression for the cells. Especially considering the compression media is ''soft'' wood.
Cells need to be compressed, but will not swell a lot considering your peak load is small (less than 1C, or if you prefer, less than 1120A)
About fuse. Why parallel fuse? Do you know ANN fuse?
Whats wring with using "soft" wood?
What?ANN fuses dont have the required current interrupt capacity and I need 800A to satisfy the inrush current for the winch motor so parallel 400A T class fuses fit the bill.
I mean wood is a really soft/brittle material compare to, let say, a steel plate with the same thickness.
To me, it's clear that if you overcharge a single cell to 5V by example, the wood will not be enough to maintain the cell swell.
But seriously, you can maintain the cells only with thread rod without overcompressing the cells. This type of cells are not weak.
What?
Interrupting Rating of 2700A, can take 1200A for 0.2 second and over 1000A for 10 seconds to 1 minute. I bet you have some serious load.
I can understand. There is a lot of information in my head around designing, build battery pack and play/see OEM electric vehicles battery pack as I do this since 2008. All this isn't easy to share in few line in a forum discussion.yabert, your welcome to to your opinion but I dont agree with anything in the first paragraph. Edit: with the exception of the steel plate, and anyone who uses 3/4" steel plate in the same application is a moron.
Thank you for not turning this into a dick measuring contestI can understand. There is a lot of information in my head around designing, build battery pack and play/see OEM electric vehicles battery pack as I do this since 2008. All this isn't easy to share in few line in a forum discussion.
You seem to have done your homework before start the build of your battery, so no problem.
My message was simple related to my design philosophy who is often Keep It Simple Stupid.
A coil spring to apply XX load on the cells is nice, but a thread rod torque at X lbs-ft will give the exact same XX load.
The XX load can vary with thread rod as they are way more rigide than a coil spring, but if your application imply only peak load below 1C, there is no real reason to design with coil spring... except if you are more confortable with it. As you seem to are.
Anyway, know that if you open an OEM battery pack build with modules or pouch cells, there is no coil spring. The OEM sometime use a thin foam between cells to act as a spring (GM Volt in mind), but many OEM compress modules without any spring (Nissan leaf, Ford Energy, GM Bolt, Renault Zoe, etc.).
Of course, they limit over compression with some structurale components.
Can't wait to see more of your build. Keep us in touch.
What?
Ok. But those cells have an internal resistance of 0.12mΩ. 4 in parallel give 0.030mΩ or 0.00003 ohm.Interrupt Rating != Fuse Rating. Interrupt Rating has to do with the ability to extinguish any arc that sets up under a short-circuit condition and needs to match or exceed the available short circuit current - which is extremely high for these LiFePO4 cells.
I have all my fuses. The two 400A for the parallel DC circuit for the winch and smaller loads as well as a 400A for the 3000watt multiplusOk. But those cells have an internal resistance of 0.12mΩ. 4 in parallel give 0.030mΩ or 0.00003 ohm.
So, short circuit current capability is monstrous.
I'm so sad to learn tonight that a high amps 12V system can't use a cheap 20$ fuse and need a 200$ fuse ?
I just realize that the A30QS fuse I use in one of my EV is also rate for DC Interrupting Rating: 100,000 AIC like the T class fuse.
Because those fuse are cheaper (45$ for the 800A), maybe it can be a good choice for noenegdod.
Thanks for the reply!,@noenegdod - Pure-lead and LFP together for a project? Dude, you've got my heart beating fast, because that was my chemical gateway way back when..
So I get your vibe and I won't go totally propeller-head. You spent great money on a great pure-lead agm (for your feel-good purpose), so please be sure to charge it at least once on an external charger before placing it into service. I'm sure you probably have already. Keep an eye on the CV's for both absorb and float. Temp-comp it if you can.
Here is the Odyssey technical manual. I keep it under my pillow.
Of course I'd recommend the Odyssey OBC-6 or higher for an external charger. Not because of the same name-brand status, but because they do it RIGHT!
Seems silly of me to spend this much thought on a reply for your lil' agm, but I can't help it.
Nice work so far - keep us posted on the project!!
On the multiplus you can limit the 120v input in steps from 50 amps down to 7.5 amps which is 900 watts and the max continuous output for the 1000 watt gen.Good looking truck. I too run a Yamaha, but I have the 2200. 4,400 hours on it and no problems. I'm wondering if the Yamaha 1000 would output enough for your charger. I don't see how many amps it needs. Any idea?
I am rethinking the 1000 watt gen though. A 2000watt is only 17 lbs heavier (29 vs 46) and hardly any bigger. I currently have an ef2400 which is 75lbs and twice the size. I think I may go with the 2000 watt. Another reason to go with this is at 15 amps input current the multiplus will still function in the "generator assist" mode but when you drop it down to 7.5 amps input current it looses that functionality and instead of assisting the generator, it behaves like a separate inverter and charger.
Edit: Ill have to look at a 2200, the 2000 max continuous is only 13.5 amps
I havent actually bought the battery for this truck yet but I have had 4 or 5 of this particular model in race cars and I have put Odysseys in every vehicle I have owned. They are a great battery. I have failed to buy an odyssey battery charger though ?.
From what I had read a long time ago off the Odyssey website, they encouraged providing as much current as they could take at 14.XXX volts, just dont exceed the recommended voltage under any circumstances.If they are healthy, don't be afraid to put the hammer down up to 1C if need be (but HIGHLY accurate voltage regulated!)
Carrying the 2400 around isnt an issue, the main issue is Im 5'6" and lifting it 5' to get it in the back of the truck is a pretty good grunt, that and the size. I am most likely going to trade it for a 2200 so I can get the 15 amps. I had originally bought it to run AC on a small travel trailer but that is no longer required.I have the ef2000isv2 as well. I had about 10k hours on it before the controller went out on warranty last year. I was about 1 month away from the end of the warranty. It is still in the shop from last October. They haven't called me and I'm in no hurry to drive 10hrs to pick it up :D
The ef2000 isv2 is 13 amps max. I originally was looking for the ef2400 that you have now. I think they are made in Japan, but I couldn't find any in stock within hundreds of miles.
The ef2200 can supply 15 amps. In the winter at 6k' elevation I can run a 750w space heater and my computer gear with the 2200 and that wouldn't happen with the ef2000isv2. The ef2200 has a hour meter on it which is useful for maintenance. It also has a 12v cigarette lighter output at 3 amps. That is good enough for a 12v refer. The ef2000isv2 has 12v too, but it is battery charging only and you can't use both 12v and 120v at the same time or it will overheat the stator and break.
I'd keep the ef2400 and use a dolly if it is too heavy. You may want more power in the future. If not, go with the ef2200 as it is a newer design and not too heavy to walk around with it (but at the limit). You can set stuff on top of it like an aux fuel supply or a table because of the handle design.
