La Ponderosa Colombia
- Feb 29, 2020
- 6
Hello all,
I'm currently designing an off-grid solar system. Initially I was looking at the all in one LV5048, however I would need to provide AC output 200 meters with a substantial load. Due to the expense in wire and the efficiency loss Im thinking off having 2 separate systems. I have a 5.5kw generator that I want to connect as a back up in-case the battery capacity is used in the night, I expect this would be once a week if that. My question is whether 1 back up generator can be connected to 2 separate all in one inverters?
This is the user manual for a MPP inverter, I don't see any reason why in theory I wouldn't be able to connect it to both systems and it could power both or one at a time. I just wanted to check if anyone knows this for sure or has experience with this? Cheers
