HamptonHall
I have 8 Lishen 272ah cells on order through Michael and am trying to figure out a configuration that I could put in some kind of battery box, as my objective is something like Will's hand cart power project (solar to come later).
Can I do this? (would like to use the Overkill Solar 8S BMS 100a LifePo4 Battery Management System for 24v DIY Batteries)
When you parallel your cells, they need to be nearly the same voltage. If you buy brand-new cells, they will come at the same voltage and you can wire them up like this:
How To Configure Cells In A Large Battery Bank
If you are building a large battery bank, you should buy larger cells. If the largest size cells cannot do the job, you will need to combine cells in parallel first, then connect them in series. This will allow you to build and manage a large battery bank with a single BMS.When you parallel your cells, they need to be nearly the same voltage. If you buy brand-new cells, they will come at the same voltage and you can wire them up like this:
Then Add A Single BMS To Manage All The Cells:
