Watch Me Build
- Jul 4, 2020
- 98
Got these hooked up for a top balance. How long do you think it will take?
It's set at 3.45 for the first push. But it seems like as it goes on it's pushing less than 3.45 to them. I started doing them individually last night because I didn't have bus bars, and as it went on the amperage was dropping and when I tested the voltage at the outputs of the power supply it would keep getting lower. Not by a ton... But when it dropped to 1.7 amps it was around 3.40v. then I'd bump it back up to 3.45 on the multimeter, and the amps would crawl over 2 again.
This pack has been going for about 10 minutes and it already dropped to 3.44v at the outputs.
Is this standard? Or is it just a cheap power supply that I will have to keep messing with?
(Sorry for the newbish nature of this.)
