Likely that stepdown is not sufficient. Both diesel heater and fridge at startup will easily exceed the 20A at 12V.
Also, that 20A are 'Chinese amps': More likely to be 10A continous in real life.
I would suggest
- Sizing up to a 40A version
- Getting a proper branded stepdown
- Maybe try adding a big capacitor to overcome inrush current, but I'm not sure if that thing actually can handle that properly.
Personally I would consider a normal 12V setup. Li-ion scooter cells, crap breakers, a cheap powMR solar controller and all thown in a box... Fine if you run it with a 50ft wire outside your house, so if it goes wrong you're safe, but in all other situations I won't even dare to run it unattended.
I would suggest
