For my example - I am guessing you have 25ah cells -
If you have four cells and want a 12v battery- then 4s (4 in series). You will have a 12v 25ah battery.
If you have four cells in parallel you will have a 3.2v 100ah super cell. 4p
If you have eight cells and put two in parallel you have a 50ah supercell then four of these supercells in parallel you have a 12v50ah battery. 2p4s
You could also put all eight in series 8s for a 24v 25ah battery.
You could also make two 12v batteries 4s each then connect these two batteries in parallel 4s2p (really 1p4s2p - but we drop the first 1p). You would need two bms’s for this plan.
Good Luck
I noticed your post as I was typing so I changed to the proper sizes.
fridge,couple lights, lights are led, maybe 15 wats,maybe tv. tv should be about 150 watts,, my fridge uses according to killowatt meter fridge uses 140 watts,,1.3 amps when running,fridge uses 1.96 kwh in 24 hours
