Landon Ashby
- Nov 10, 2019
- 11
1. Do I need an inline fuse for each solar panel + before going into the branch connector or 1 after the branch connector?
2. Wills diagram shows 4 awg being used for just about everything. Even the solar wires coming in to the controller. The wire that comes off the branch connectors is 8 awg. Is the 8 awg large enough or should I be combining the 14 awg wires from the solar panels in a different method and using 4 awg into the controller?
3. If this system is placed at the rear of a minivan is 4 awg large enough to make the run to the starter battery or should I be looking at gauging up to a 2 awg for that wire?
4. I will definitely be limited to 400watts of solar on my roof. Can I increase my battery bank later on? I'm think 2 12v100a Battle Born Batteries will fit my needs of running a 12v fridge and a 600 watt microwave for 15 minutes a day. Buy if I find I need more Battery can I add a 3rd? If I can does anything change? Like the gauge of wire I need to join the batteries or any of the fuses or circuit breakers needed.
5. If by some bad luck I actually need to jump start my van, do I need to disconnect the wire that connects my starter battery to the system?
