And 50a is WWAAYY overkill for your panels, try a 15a instead, that'll be plenty.
+1 on the Class-T fuse, $60 with 150a fuse and holder at donrowe.com Replace that 200a on the batteries with the Class-T and replace the 150a ANL with a bus bar. That'll make life much simpler.
8awg from the panels and 4awg from the controller are about twice the size you need for that short of a run. You can easily use 12AWG and 8AWG respectively.
Likewise 8awg is going to be more than plenty to the 12v fuse block. You can use 10awg there and be OK but 8 gives you a little headroom.
Your paired 4awg wires can be replaced with a 2awg just fine.
