Review my 400w solar diagram
tacotuesday8
Chicago
I've been watching about 100 youtube videos and reading all I can the last few weeks, I'm looking to make a simple cargo camper, and 400w solar seems about right. I'm easing into it financially, so only have a 100ah battery at the moment, but would some of you experts be willing to review my wiring diagram to see it I have everything in there okay and there's no major flaws? There is a ton of ways to do this it seems, so your help would be really appreciated!
I'd put a breaker or switch between solar and SCC. What wire are you using there?
If you specify length of the wire run, it would be possible to determine if the wire gauge is appropriate.
think that breaker size is appropriate @MisterSandals? I also took someone's suggestion to split the distribution panel from the inverter so the inverter could be shut off when not needed.
