Good evening everyone. I have read a ton of great information and so glad I found this site to learn with others. I have a idea in my head that im trying to figure out. If a battery bank is charged to 48v buy 10x 220watt panels is there a way to regulate the voltage feeding into a 12v inverter? My inverters are both 12v 5000watts 10,000 peak. and can take 15v. during the day I can power all my needs just fine with the charge controller steady providing 14.5 volts. In the evening the 8x 12v lead acid battery's Im currently using drop super fast if I use a heater or cooker. I would like to use 2nd life nimh hybrid cells with 4x banks of 48v each that will discharge from 48v to 12v running a heater over night. I have been testing the nimh cells at 12v and plan to use them like that if the 48v is not something that is possible. Step down or "buck" converters will not carry the amount of power needed for a 5000watt inverter. what I am looking for is a devise that will allow me to steady feed the inverter 14.5v from a 48v battery pack hopefully this will make since to people reading. Its hard to explain whats in my head down on paper. thanks
