ProfessorPeabody
- Mar 17, 2021
- 4
I recently purchased a 1989 Bluebird Wanderlodge motorcoach. My family and I will be traveling in it full time over the next year (minimum) and would like the option of living "off the grid" when desired.
I respectfully request your assistance in the design!
My first phase of the build will not include PV panels to cut cost.
Below is my "wish list" which I hope will allow several of you to assist me in building this system (and maybe have fun with the challenge!). Please feel free to correct me on any of the statements I've made or provide better alternatives with your opinion/experience.
General Info:
Thank you all so much in advance for any help. I hope to figure out how to make a pretty schematic of it soon as well.
General Info:
- The coach has an existing electrical system (that I don't fully understand at this point but working on it).
- 50 amp 240VAC shore power capable (which is split into two 120V/50 amp) for a total of 6kw on each leg.
- 15 and 30 amp 120VAC shore power capable.
- 15kw diesel generator that feeds both legs with 120VAC/50+ amps.
- It has an auto-transfer switch (i think) that switches from generator to shore power.
- Generator has an alternator and 12VDC battery (I'll likely keep this system isolated)
- Main engine (Detroit 8v92 diesel) has an alternator and 12VDC battery system. I'll likely keep this system isolated and continue to run the 12VDC components in the coach off these. May add a 12VDC LifePO4 battery at some point.
- Off Grid, use the generator at maximum capable power to charge the 48VDC battery. Hopefully only needing to run the generator a few hours a day.
- On Grid, use available power to charge batteries and supply the coach with power and "boost" capabilities (supplement low shore power with battery).
- Driving, use engine alternator to charge 12VDC and 48VDC batteries. (DC to DC charger here? Orion? suggestions?) (battery to battery charger?)
- PV panels on the roof in the future, but not yet.
- I believe I'd like a 48V system (keep volts high and amps low=better)
- I believe I'll build my own from eve LF280k cells
- I believe a minimum of 14kwh battery (16 cells) to start. If i can keep cost down I may spring for double this.
- Looking for suggestions on BMS (this decision likely driven by the choice of inverter/charger).
- Victron Dual (one for each leg) Quattro 5kVA (any more affordable options suggested?)
- Goal here is to be able to supply the coach with similar power that shore or generator can do.
- Lynx "power in", "shunt", and "distributor" (again, suggestions welcome)
- Cerbo GX for connectivity
- Surge protector for shore power (watchdog?)
- Various disconnects and fuses (add more info here later).
- 3 x 15k BTU AirConditioning units (1.2-2kw each w/compressor running)
- Microwave/oven combo (unknown at this time)
- Refrigerator (300W)
- Air Fryer (1.7kw) everyday use roughly 20 min/day
- Ice maker (unknown but we may not use this, we're not ice people)
- Stove (dual eye electric) (we'll likely use a propane griddle mostly, have a 45 lb tank on board)
- Water heater (unknown)
- Baseboard heating (don't want to know, haha, use propane heat if possible)
- Lights (working on converting all to LED)
