shrubshaker
Hello again!
Being a new RV owner and novice in the solar industry I have a dilemma and question.
As I mentioned in my previous post, we just bought and RV (used). Here’s how the solar system is set up in the converter box and directions according to the lady we bought it from.
In converter box there is a 15 amp breaker (3rd from left in picture) and we were told when it’s on it’s charging the batteries and when it’s off we’re using solar power directly, no juice from the batteries is being used.
I’ve been having problems with our battery system only lasting 3 to 4 hours a night. So this morning I started hunting around for the problem.
I unplugged everything in the RV but the inverter still showing 620w draw when the breaker in the converter box is on.
I turned off all the breakers and confirmed there was zero draw on the inverter. Turned the breakers back on except for the solar breaker in the converter box and no draw.
Then I started plugging a fan and a couple of other things in with the 15amp breaker off and the expected draw of 150w showed on the inverter.
I turned the converter box breaker back on with the fan and other things still plugged in and the inverter showed 770w draw… Oh I forgot to mention that the fridge and water heater are running on gas, no electric draw.
What is eating up all that power, 620 watts worth, when the solar breaker in the converter box is on and nothing in the RV is plugged in? I don’t get it…
