I received 4 of these batteries for free and I'm hoping to use them as the start to a solar generator. They're 8s li-ion batteries, epoxied into these enclosures. I can't break them down without destroying the plastic, since they're siliconed together. Is there a difference, other than cut off voltages, between lifepo4 bms and li-ion bms? Could I use a lifepo4 bms on these batteries until they're eventually replaced with lifepo4 cells? I know I'll be losing out on capacity with lower operating voltages but I'd like to build a 48v system and not have to rebuy components later. Also, I did some searching but was unable to find any info on these. If someone is familiar with them please let me know. The person who had them previously wired up one of the connectors to the balance leads, so I can wire a BMS in, also curious about the 13 or so other wires coming off the board...
