Looking for sanity check on my plan to use 8 x HESP 12kW for grid tie setup with full offgrid capability. Thanks in advance for any advice
Somewhat rural Texas property with a lot of ACs, pumps, etc. Need to be able to bypass inverter setup and run house panels directly from grid if inverters are not working (divorce is costly).
Diagram included. It's pretty simplified but hopefully explains what I'm thinking.
I have 320/400 single phase service. Meter has 2 sets of lugs. Each is connected to two 200A panels. I want to continue to make 200A available to each set of panels when grid is available, and ideally also make 200A available when grid is down to avoid tripping from high inrush devices.
Proposed Setup
![main.drawio (2).png main.drawio (2).png](https://diysolarforum.com/data/attachments/232/232201-c0609f85c9d205b6468481fe20f9e40b.jpg)
Proposed Setup
- 8 x 12kW hybrid grid tie inverters; 1-4 connected in parallel, 5-8 in parallel
- Eyeing the HESP48120U200-H right now given price (~$1900 per unit)
- Inverters will be export limited to prevent >320A back to grid
- PV: initially will use already installed 65kW in 16 strings
- Batteries: 15x 280Ah 48v batteries connected to all inverters via busbar.
- Each battery independently connected to busbar with independent class T fuse at busbar (seems to be current forum consensus). Busbar to be contained in 12" gutter
- Thinking of something like this for busbar - https://www.amazon.com/BELLA-BAYS-Grounding-Positions-Insulators/dp/B0BNKVV6TK/
- House panels will continue to be connected to grid via main breaker that is normally switched off. Inverters will backfeed into house panels. Lockout to prevent main breakers and inverter breakers from being on concurrently
- 15 strings of 9x Canadian Solar BiHiKu bifacial 450W CS3W-450MB-AG
- 1 string 10x Talesun 400W (Black) 108 Half Cell Bifacial
- Future: Up to 16 additional strings Jinko 54HL4R-B (type N) 440W, up to 12 panels long each
- Initial plan will be to use the 16x existing strings across all 8 inverters (leaving them quite underpaneled). I ordered a large # of Jinko 54HL4R-B (type N) 440W panels to potentially add an extra 16 strings. They should arrive in next couple weeks but will take a lot of time to get to installing
- 500ft from inverters to panel, so keeping string voltage high is helpful
