42OhmsPA
What's in a title?
Exactly, you could create an automation to run in SBU until XX.X battery voltage then flip to UTI, you could also add another condition based on time or other parameters.You have me back at trying to figure out how make the ASP work. So tempting.
Use SA to change the mode, and ASP responds pretty quick to a change in mode (UTI to SBU, whatever else is needed to use battery instead of grid)
I currently use one to reduce charging current, works great.
