David947
I'm working on a residential hybrid solar system where the house AC circuit is already earth grounded and connected to one rod. I'm having 9 strings of 8 panels in series, each string is connected to an SPD and the ground coming out of it is connected to the house main AC panel grounding busbar. My question is for grounding the solar panels mounts and frames, is it ok to connect this ground wire to the house main AC panel busbar?
I'm having a hard time deciding as the topic is confusing and I already found conflicted analyses.
Thank you.
Thank you.
