FlictedFisher
- May 26, 2022
- 1
I am building a DIY 48v battery using 16 EVE 304Ah LiFePO4 Prismatic Battery Cells. Please help me choose a good reliable BMS for this system. I have been reading posts for days & have become a lot more educated on brands (overkill, JK, JBD, daly, Seplos, ext) but no closer to a brands model that is a good match. Seems to be a lot of variables to match with the system or am I overthinking things a bit. Thank you for your assistance.
System :
2 - EG4 6.5kW Off-Grid Inverter | 6500EX-48 | 6500W Output | 8000W PV Input | 500V VOC Input | All in One Solar Inverter
I have (Q. PLUS L-G4.2) Solar panels that I am pairing with 2-EGR6500Ex. I have built 2 ground mounts that will hold 18 panels each. I am planning on 9 panels to each PV input so 18 panels per 6500EX-48. I will also run grid power to these units as well.
panel specs:
330W
short circuit current 9.49
open circuit voltage 46.55
current at maximum power 8.91
voltage at maximum power 37.02
System :
panel specs:
330W
