I think you're missing some digits or something is odd in the math.
The J1772 (EVSE) standards dictate a minimum of 6.0 amps (not 0.6)
That is 720 or 1,440 watts minimum.
Yes, the minimum is 6A, not 6W. Meaning a minimum of 720W @120VAC or 1440W @ 240VAC of available solar energy before it begins charging.
I just read the standard and it is 50% using 7 bits resolution (below 50% of max), so ~0.4% increments or 0.25A per bit.
So if charging at Level 1 (max of 12A @ 120V or 1.4kW), it is 5.5W per step below 0.7kW or 11W per step above 0.7kW, while charging at level 2 maxed to 16A @ 240V (3.8kW), it would be 15W per step below 1.9kW or 30W per step above 1.9kW.
If you're array is 1.14 kw, you're going to need more panels to support charging a car.
Sorry, I was not clear.
I’ve got a 4kW AC-coupled array capped at 3.5kW. That is the array that exports now and that I will need to capture in a battery rather than exporting I’m the future.
So no issue reaching the 6A minimun.
It’s not practical for me the expand that AC-coupled array but I have a second DC-coupled array used to charge my house battery (that powers my GTIL inverters).
I can easily add additional panels to that DC array and that is an easier way for me to compensate for AC-coupled energy list to export (because of the ‘steps’ in EVSE charge current) rather than looking for a complicated way to reduce that remaining unwanted export.
I believe Hedges was talking about the decision to charge the car first or battery first. Which gets charged first?
In my case, both get charged in parallel during the day.
DC array charges house battery.
AC array charges EV battery with excess energy after powering loads.
Overnight, the EV’s V2L port recharges the house battery like a generator when needed as the GTIL inverters offset home consumption.
For me it makes sense to charge the car first. But, with 1,440 watts as the base and steps of 240 watts, the home battery always gets some on a sunny day.
But, you've got DC coupled solar? I suppose that changes things. But, I'm stills unsure what you're going to do,so I can't offer much useful advice.
Today, I use AC array to power loads and export any excess during the day.
The house battery is charged from a second DC array which offsets loads as long as battery energy remains after the sun sets.
I’m really happy with the way it works but after I get bumped to the successor tariff and export gets credited at ~25% retail rather than the full retail credit we get today, I need to find a way to capture as much AC energy as possible to avoid export.
So charging a V2L-capable EV with excess AC-coupled solar energy using an EVSE charger configured to consume most of the energy that otherwise would be getting exported sounds like the easiest long-term solution.
Instead of getting exported to grid, most of the excess AC generation gets stored in the EV’s battery (we’re talking about ~8.5kWh per day in December, so no big deal).
Then, as the GTIL inverters drain the DC energy that had been stored in the house battery from the DC array, a ‘generator’ relay can be used to turn on a 10A / 320W battery charger powered by the EV’s V2L port to keep the house battery topped off above empty and powering the GTILs (draining that ~8.5kW that had been stored).
The only thing I don’t like with this solution is the poor efficiency - I figure I’ll only get ~660Wh of usable AC power to offset consumption through this multi-hop path for every 1000Wh of AC energy I put into the EVSE rather than export it.
But 66% is waaay better than the 25% my utility is offering
If there was a way to output grid-tie power from the EV (V2G?), that would allow me to improve efficiency to ~81% but that requires a grid-tie inverter in the EV to sync to the grid signal as well as some control mechanism to limit the output power to the level needed to offset loads (as my GTIL inverters do today).
A bidirectional EVSE-like EV charger that can tell the EV when to consume enough power to minimize export while also being able to tell the EV when to export enough power to offset consumption and minimize import would be a dream, so hopefully something like that is in the works and will be available for me when the time comes…
