Hi Kish,
The "recondition" voltage will be inapplicable for an LFP bank, as reconditioning must be turned off entirely -reconditioning is for Pb batteries only, and is effectively a deliberate overcharging of a lead battery to burn off sulfation, which is not applicable to LFP batteries. Changing the battery preset to lithium will automatically turn off reconditioning, but care must be taken when selecting a "user-defined" battery preset, because reconditioning is not automatically turned off in a user-defined preset.
The "storage" voltage will be a lower voltage setting than "float" voltage; for my batteries (ignore the screenshot, again I'm running a beta FW version and the settings reverted to default when I connected to the device to take screenshots) I set bulk/absorption to 14.4v, Float to 13.6v, and Storage to 13.2v. Thus, when the batteries have charged to ~90%, the charger goes into Float at 13.6v (which is my batteries' resting voltage) and after ~4 hours at Float, with no loads on the batteries and no fluctuation of voltage, the charger goes into Storage mode, which is basically "asleep" - it's passing 0 current into the batteries unless the battery voltage falls below my set Storage voltage of 13.2v; if the battery voltage falls below that setting, the charger will turn back on and run a full charge cycle as necessary.
