AC drain line in wall
Jet
Would installing a air conditioner condensate drain line inside of wall caused the pipe to sweat on the outside because of the cold water. This would added moisture inside of the exterior wall might lead to mildew in the wall or on the drywall. Has anyone built a AC drip line into the wall and has a cause problems. Thanks
As mentioned by 12voltinstalls, indeed insulating the drain pipe will solve this.
In addition, be sure that connections in the wall are well glued together or fixed very well.
If the line is clogged, they often do after a couple of years, you might need to put some pressure on that line to remove that.
