Paul Smith
- Oct 1, 2022
- 4
I've recently installed my own PV system using 8 x JA Solar 405w panels and a Solax dual mppt 3600w inverter. The panels are mounted on a frame on an outbuilding flat roof, everything has been done by myself with the exception of the grid connection which was carried out by a qualified electrician. I have sent off a G98 to my DNO which has been accepted but i'm not receiving any export payments as it's not MCS certified.
I have been monitoring my useage for a long time and I use 16Kwh per day, my monthly bills are always 480Kwh +/-10Kwh. My system went live on the 1st of September and during the month I used 300Kwh which is 10Kwh per day, a reduction of 6Kwh per day which is very pleasing, a saving of 180Kwh.
However something doesn't quite stack up. According to both my inverter and the generation meter I generated 255Kwh during the month which suggests that I exported 75Kwh. However my Shell Energy smart meter shows an export reading of 133Kwh, so it appears to have over read by 58Kwh??
Nothing else has changed so I wouldn't have used less than a "normal" month. Is it possible for the smart meter to over read the electricity exported?
Has anybody else seen this on their systems?
Thanks in advance
Paul
Thanks in advance
Paul
