Hello.
Due too the short distance from my solar panel to my 40a controller - less than 3ft, I was thinking of just snipping off the mc4 connectors to the cable that is already there at the back of the solar panel and wiring directly into the controller, instead of using any further length of cabling in order to minimize any voltage drop.
But this cable size is only 2.5mm 14awg - max 20a. 20a is enough for me for now anyway, so thats fine. However, lets say, my controller is further away and hypothetically - as my single solar panel is 200w, I wanted draw more amps over 20a, I would of course leave the mc4 connectors on the solar panel cable and step up to say a 10 or 12 awg cable by connecting the mc4s. This is the bit I don't understand, I'm assuming the solar panel cable 2.5mm 20a cant feed any higher Amps into the larger cable 20 -30a?
Every video installation guide I see, they just connect an extra length of whatever thickness to the solar panel cable and the other end to the controller, seemingly thinking they are using the correct thickness.
Even if i added an extra 100w solar panel to give me 300w, the standard 2.5mm cable coming out the back of the panel wouldn't allow me to draw more than 20a
Am I missing something? Do people remove the cable from the solar panel and fit thicker cables? because I've never seen it on any video
